I am using Digirig with Soundmodem to log onto a BBS and retrieve emails (ARES BBS using Outpost). If the email is very short, no problem. However, if it is more than a few lines long, it seems to time out. I can see about 1/2 of the email downloading then it stops and it never totally downloads.
I am thinking maybe there is a buffer size setting, but new to all of this. If anyone can offer suggestions, much appreciated.
Digirig is a soundcard and there is no issue to continuously send or receive audio with it. The timeout maybe on your transceiver or the remote station. For a test just try holding PTT without even Digirig connected. Do you get the timeout?
Thanks, but I now see where the data is coming across to the soundcard, so I guess it is working OK, but only half the message gets into Outpost, so it may be an outpost setting. There was some init commands that outpost suggested I put into a modem doing AWGPE, I put them in the soundmodem init file but seems to still be a problem.
I think the problem is, is that the command prompt that soundmodem sends back is not compatible with the BBS I am on. Is there a way to change the command prompt in sound modem?
I may be wrong on this, but I would think that if any of the principal settings were off, you wouldn’t be able to exchange any emails, short or long.
