Digirig TX and TX Audio Working, RX Audio not working
Hi all,
I have recently ran into an issue with my digirigs. I have 3 digirigs, all of them have stopped providing audio in to the pc from the radio. They were all fine, the only common denominator between them all being they were plugged into a mini pc and after that, audio in stopped working. They now do not work regardless of radio or computer. PTT still gets triggered just fine, and I am still able to transmit audio out from the pc to the radio.
Does anyone have any ideas as to why it is not working? Perhaps the usb connection on the mini pc is shorting the digirigs and causing hardware issues? Prior to plugging one digirig into the mini pc, I plugged it into another computer I had and confirmed it was working. It then stopped like the others after connecting to the mini pc. Please let me know if anyone has any ideas, as the three digirigs combined totals $210 of wasted money if they are truly bricked.
EDIT: It is not working regardless of OS. Linux and windows both have no audio in, but worked previously. Both can still trigger PTT and Audio out
It’s possible that the mini PC has some power or ground issue that caused high voltages to Digirigs’ inputs damaging the audio codec. You might want to use USB isolator with that PC in the future.
Please PM for service arrangements.
