New to Digirig and Windows 11! Last time I used a digital mode for PMS Packet it was with a KAMM+ TNC and a much earlier version of Windows. Hooked up the Digirig with the proper USB cable and found the USB Audio Device and after downloading and installing the USB to UART Bridge drive saw COM3 for the port. Went to the step for setting up sound devices but need to know do I rename what is there for playback and recording to Digiirig?
Once you identify the USB PnP Sound Devices in Windows 11, you can rename them to something meaningful to you. Have you identified them? That is your first step.
many do, simply for easy/quick identification when setting up new/more digi-soundcard mode software.
it is also helpful when making sure which soundcard is the default.
the name changing obviously doesn’t follow the digirig from computer to computer so it’s up to you if you’d like to rename the ‘usb audio device’ or not.
