good morning guys I have a small problem with the digiring for ft-891 and wjyx/FT8 with split, let me explain better: let’s suppose we are at 7.074 or 14.074 when it goes in tx it lowers the frequency eg 7.073, when it goes back in rx it does NOT go back to 7.074 but remains at 7.073 so when it goes back in tx it goes down to 7.072 every time I have to go back manually to 7.074 you understand that it is a problem, for the rest everything works perfectly, can someone give me some advice, I looked at many tutorials but I can’t find the solution thanks 73…de II2LNP
Tiziano,
There may be a situation with the split settings conflicting in software settings and in transmitter settings. Turn off the split mode in the transceiver and let the software do the shifting when needed. Try fake and rig in WSJT-X to see what works better.
hi thank you for the reply, I tried with fake and disabling the split in the radio in tx it moves but then does not return in rx on the original frequency i.e. it remains moved, with the split enabled in the radio and rig on WSJT-X everything works perfectly, so in my case split enabled and rig in WSJT-X thanks 73
