I had purchased a digirig for use with my Yaesu FT5D with appropriate cables a while ago. I now also have a Yaesu FTM 300D…can i use the same digirig “box” with the 300? I know I’ll need to purchase the 10 pin cables…just not sure if HT’s digirig is the same and ok to use…sorry…I’m new to this digital world.
Dane,
The Digirig configuration only matters for transceivers with CAT control. Your Yaesu FT-5D does not support CAT control so you likely received Digirig in it’s default configuration (Logic Levels). That happens to be the exact configuration that your Yaesu FTM-300D needs if you plan to use it with the cable facilitating the CAT control.
