DR-891 Compatible running WSJT-X with Ten-Tec Eagle
I can confirm the USB interface of the DR-891 and Yaesu DIN5 cable https://digirig.net/product/yaesu-din5-cables/ works with the Ten Tec Eagle 599. This should also work with the Argonaut VI Model 539. I can also confirm GPIO PTT works with WSJT-X by creating hamlib_settings.json with the following lines of code and saving it to C:\Users{username}\Appdata\Local\WSJT-X
        "config": {
                "ptt_type": "CM108",
                "ptt_bitnum" : "3"
Also Jupiter 538?
Hi Virgil,
Yes, the Yaesu DIN5 cable Yaesu DIN5 Digirig Cable Set – digirig should work with your Jupiter 538. I recommend using Digirig Mobile as that radio has a serial port.
