DR-891 - DigiPi
So my DigiRig DR-891 just arrived and there’s a problem. If I hook it up to my MacBook Pro it works perfectly. If I hook it up to my Linux Mint laptop it works perfectly, but if I hook it up to either of my DigiPis - Pi Zero 2 W or Pi 5, within 5 seconds of booting the Pi the rig transmit relay and indicator light start going on and off several times a second until I turn the rig off. Troubleshooting I found that it was the audio connection. If I just have the USB CAT control cable connected it works fine. If I return to my DigiRig Mobile everything returns to normal.
Any suggestions?
Check gpsd settings. Search results for 'gpsd' - Digirig Forum
I checked /etc/default/gpsd and USBAUTO=“false” is set to false. Any other ideas?
Rather than check the configs:
su -
ps -auxw | grep gpsd
to see if gpsd is running.
