DR-891/FT-891/Windows 11/Low audio out to radio?
Everything was working great, but something happened and now I cannot get the signal level as displayed on my FT-891 to adjust to an ideal level as displayed by the meter when set to ALC.
I went back through the setup as per the manual for the DR-891. But I can no longer adjust the audio level too be the 2/3 scale of the ALC like I used to.
I do not know if my radio input has an issue, or if the DR-891 has an issue or if it is Windows 11 causing the problem.
The radio has the input and output gain for the DATA mode set to 50% as when it was working.
I am hoping I have something in Windows for the audio incorrectly set.
Has anyone else experienced this?
Can someone point me to a YouTube video, perhaps?
UPDATE - Ugh… Not sure when or how it happened that the settings were changed…
Fix - Input in WSJT-X to Mono, Output to Left was the fix.
