DR-891 Stopped showing in the Device Manager
Hello!
I recently received my DR-891 and configured for my FT-891 on Windows 11.
It was working great and I was using mostly the cat with the N1MM and Log4OM. I realized it stopped working and went to check the device manager to see if the port had changed for some reason and I realized it’s not even showing in there anymore.
I still can get the audio from the radio but windows doesn’t detect the USB. I haven’t updated windows nor changed the USB cable I was using to connect the digirig to the PC.
It didn’t stop in te middle of the operation. It was working in a session. Then I turned off the PC and turned it on again the next day and realized it wasn’t working anymore.
Would you have any tips on what I could do to figure out what’s going on?
Andre,
Can you clarify please, does your computer still see Digirig’s sound card?
Please note that the COM port comes from your radio, it is just connected through Digirig’s internal USB hub. You can still connect your radio to the computer directly and see if it correctly detected.
Yes, I can see the sound card. I think it was something with the physical connection. I checked the connectors this morning, not on the radio but on the digirig, and visually it looked all well connected but to make sure I disconnected all the cables from the digirig and connected again and it’s working fine.
I suspect it’s the red plug of the cable that connects the digirig to the radio because it feels a bit loosen.
Thanks for the help! 73
Please PM if it gives you more trouble and we’ll get it sorted out.
