DR-891 w/FT-891 WSJT-X using a Mac M1 w/Sequoia will not work
Background:
WSJT-X using an IC-7300 works fine on the Mac (Sequoia)
WSJT-X see the correct com port, Silicon Labs. CAT and Audio
WSJT-X w/DR-891 using the FT- 891 on a windows 10 computer works fine.
WSJT-X see the correct com port. CAT and Audio
Setting up the WSJT-X with the DR-891 on the Mac will not establish CAT control.
The choices in configuration for com ports will not show the Silicon Lab’s USB port.
I can see the Silicon Labs USB when I use the IC-7300 on the mac, so the Silicon Lab’s com port is installed on the Mac is not showing up.
I’ve looked a security and permission on the Mac and can’t find any setting to enable or disable the usb driver.
So and ideas, what am I missing?
Are you able to establish CAT control of your FT-891 when you connect it to the computer directly?
No, I can’t establish cat control with a direct connection from the Mac to the FT-891.
Do you see the serial port correctly listed in Sequoia when directly connecting FT-891 to your computer? FT-891 uses the same UART chip as IC-7300 so the same driver should pick it up, the only difference is that with FT-891 there may be two ports: standard and enhanced.
Ok,
When the Mac is connected to WSJT-X with the 7300 is see two ports:
/dev/tty.usbserial-1110 & /dev/tty.usbserial-1110 both the same.
With WSJ-TX (with the 7300) I can select other ports (probably meaningless ports) and then re-select the correct port, /dev/tty.usbserial-1110. Cat control re-connects.
When everything is working with the 7300, I leave WSJ-TX configured for 7300 and shutdown WSJT-X.
I now move to the FT-891, power on the FT-891 start WSJT-X. Of course I see the error messages.
The usb port in configuration is still showing /dev/tty.usbserial-1110, I don’t touch that port setting yet, I select the radio (FT 891) and then the baud rate configured for it.
I now test CAT and it will not connect.
At this point I use the dropdown selected for other ports, try another port just for fun, and of course no go, again I use the dropdown select the port /dev/tty.usbserial-1110 but guess what? it’s not there.
Something interesting:
When I launch WSJT-X without the 7300 connected (of course get the error messages) but looking at the configuration menu with the 7300 disconnected I don’t see the port, /dev/tty.usbserial-1110, but without changing anything I plug the 7300 in and right away the ports show up /dev/tty.usbserial-1110. So basically, as soon as I connect the 7300 the MAC goes out and reads the ports, my guess. Or the 7300 says hello I’m here.
You can use ls /dev/tty.* command in the terminal window to list the serial devices before and after radio is connected to see what changes.
Nothing connected
duanedahlberg@Duanes-MacBook-Air ~ % ls /dev/tty.*
/dev/tty.Bluetooth-Incoming-Port /dev/tty.wlan-debug
/dev/tty.debug-console
Icom-7300 Connected
/dev/tty.Bluetooth-Incoming-Port /dev/tty.usbserial-1110 <usb port used for the 7300
/dev/tty.debug-console /dev/tty.wlan-debug
FT-891 connected
Since Windows computer recognizes FT- 891 we can assume that it’s a driver issue, not the failure of the radio.
Try installing CP210x VCP Mac OSX Driver from Silicon Labs website: CP210x USB to UART Bridge VCP Drivers - Silicon Labs
Yes it now works. :+1:
I tired two times to install the driver via the install app that it downloaded, it failed twice, the third time I use the command line in terminal to install and that works, said install successful but it still did not work. After reading installation notes I had to enable the extension for the driver. Once I did that the drivers showed up.
I already had the silicon driver installed, came with the Mac but now this second driver works, I just have to try the various choices and try Test CAT until I got a green Cat.
So thank you, thank you, Thank you…
Duane - W6DAD
Thanks for sharing the process. Glad to hear it worked.
