I’ve been using the DigiRig 8xx cable set up with my Yaesu FT 891 for a while with no issues. Then I learned of the DR 891 product, and went ahead and bought it because it saves me a single, valuable serial port on my laptop. This new devices creates two devices, /dev/ttyUSB00 and /dev/ttyUSB01 as expected, with one of them being the radio’s cat control via it’s USB device. Here is my problem: I am unable to chat the radio via rigctl like I was with my 8xx device. Without that, I’m dead in the water. I think I have a failed component, but without a second unit to swap parts out against, I am in the dark. I’ve tried chatting it on both ports, but am unsuccessful. I’ve tried attaching rigctld to each port as well, but that’s not interactive. Can anyone help me with this?
Steps to reproduce:
connect red cable end to digirig 891 and black cable end to dirigig 891 and plug into USB and 6pin mini-din respectively. It’s impossible to switch cables on the radio side and the digirig itself is color coded. Plug the USB end into laptop with proper USB cable.
validate OS has seen the USB serial ports on the digirig
lsusb | egrep -E ‘0d8c|10c4’
Bus 001 Device 019: ID 0d8c:0012 C-Media Electornics, IN. USB Audio Device
Bus 001 Device 020: ID 10c4:ea70 Silicon Labs CP2015 Dual UART Bridge
so here it sees the FT-891 on Device 19 and sees the Digirig second USB as device 20.
The Digirig 8xx differs because it’ll have a second device on 10c4:ea60 as well for the second port. This tells me the passthrough on the digirig 891 is there and it sees the digirig internal usb serial interface.
using rigctl daemon, establish a connection to the FT 891 CAT control
rigctld -m 1036 -r /dev/ttyUSB00 -s 38400 -P RIG
Note this will just hang and you have to leave it active in that window
open a new window and try to talk to the serial port via the rig virtual device on setting 2: rigctl -m 2
This should dump you into the cat control. I should be able to type ‘f’ and hit enter and get the radio’s VFO current frequency. This fails and rigctl closes the port. Note that in ubuntu, there is no selinux and no iptables firewall by default.
It is, I do see two separate USB devices from the single digirig cable, but I’m not able to connect to the radio through rigctl. Works great on the digirig 8xx unit, but not on the digirig 891 unit. Maybe I have a bad unit, I dont know. I dont have a known good working one to test against.
What are the device IDs for each USB port on the Yaesu FT 891, respectively, and which device ID is for what function? Did they really use two different USB chipsets in the radio? I will be doing the troubleshooting you requested and will get back to you shortly, I was out of town when you asked me to do that troubleshooting.
Enhanced USB\VID_10C4&PID_EA70&REV_0100&MI_00 - use for rig control
Standard USB\VID_10C4&PID_EA70&REV_0100&MI_01 - use for PTT by RTS or DTR, CW keying if separate port is required
Sorry, it’s been a while, I had to get a windows machine per your request to troubleshoot this problem.
When I plug my Digirig 891 into a windows machine, I see two Serial ports, com9 and com10 and they show up as Silicon Labs Dual CP2105 USB to Uart bridge: enhanced com port (COM9) and standard COM port (COM10).
Is this correct and what I should expect to see? I’m not seeing the 891’s serial port at all. I purchased a USB cable from you as well and that’s what I am using between the digirig and the PC.
Just got my DigiRig 891. Brand New 891 as well. After an hour of troubleshooting (I am versed in Digital Configs across all the Yaesu’s) and confirming all was as it should be, had sound coming out the Digi, etc, I found that the DIN cable provided is either a bad match or the pin-outs are loose. Moving and holding the cable in an up position sends audio to the 891 but letting go drops the tone. I tested with another DigiRig cable and it was fine hence its the cable. Is it comon for these cables to be bad new?
No Kevin, it’s not common. I think you just got a bum cable. The good news is the digirig folks stand behind their product. Reach out to their tech support and they’ll probably swap it out for you.
