Elecraft KX3 with DigiRig mobile using fldigi ver 4.1.23
Elecraft KX3 with DigiRig mobile using fldigi ver 4.1.23 - WD0UG
Op Mode
…PSK / BPSK-31
Configure
…Config Dialog
…Modem
…Psk (use defaults)
…Rig Control
…Hamlib
…Check Use Hamlib
…Rig: Elecraft KX3 (Beta)
…Device: e.g., COM7
…Baud rate: 38400
…Stopbits: 1
…Check PTT via Hamlib command
…Check Audio on Auxiliary port
…Soundcard
…Devices
…Check PortAudio
…Capture: e.g., DigiRig Mic (2-USP PnP Sound Device)
…Playback: e.g., DigiRig Output (2-USP PnP Sound Device)
…Check Device supports full duplex
…Right channel
…Check PTT tone on right audio channel
Set KX3 power to 5 Watts or less
Connect DigiRig mobile with correct cables
Power KX3 on
Mode = USB
Data = Data A
Tune to 7.070 (or other PSK-31 frequency)
Press RsID CQ on fldigi screen
73 Doug WD0UG
