Hello all. I setup my Icom IC-7000 for portable operation with a DigiRig for FT4 and FT8 operation while camping. Regardless of my power settings I keep getting an error message and after the initial broadcast, it stops transmitting. I’m using the correct cables, which I bought when I bought my DigiRig. I’ll paste the message below and perhaps someone can help me.
ONE MORE NOTE: When i bought the cables for my DigiRig, I did not see cables listed for the IC7000, so i bought the cables for the IC706. Could this be a part of the problem? Also since this radio is older, I’ve not been able to find any help with the settings in the radio itself.
Hamlib error: read_string_generic called, rxmax=4095 direct=1, expected_len=1
write_block(): TX 7 bytes, method=2
0000 fe fe 70 e0 1c 00 fd …p…
read_string_generic called, rxmax=200 direct=1, expected_len=1
read_string_generic(): Timed out 1.000 seconds after 0 chars, direct=1
29:frame.c(185):icom_one_transaction returning(-13) Communication bus error
28:frame.c(455):icom_transaction returning(-13) Communication bus error
27:icom.c(5067):icom_get_ptt returning(-13) Communication bus error
26:rig_get_ptt: elapsed=4414ms
26:rig.c(3343):rig_get_ptt returning(-13) Communication bus error
while getting PTT state
Timestamp: 2024-03-30T02:15:36.033Z
