Fldigi Configuration for digirig on Raspberry Pi 4?
Does anyone on this list have experience with successfully using a digirig with Fldigi on a Raspberry Pi ? If so, I’m hoping you can help me. I’m really stuck…
I am having a new problem with getting Fldigi working correctly with a digirig on my Raspberry Pi 4.
A month ago I had the digirig connect with FLDG correctly and it showed up in Configuration > Soundcard > Devices as “USB PnP Sound Device:(Audio 5,0)” as seen in (Screenshot (1) below).
(1) Fldigi and digirig Configuration > Soundcard > Devices (one month ago):
In the meantime, I had some trouble getting my GPS to work and I spent some time fiddling with my USB connections and ports. I think it was a USB 3 Hub interference issue and I did get the GPS to work again finally by using several ferrite rings on the various cables coming in to the Pi.
But I must have screwed something up, because now, when I try to connect the digirig to Fldigi, the device no longer shows up in the dropdown list to select as “USB PnP…” above, but all I see is the lists as seen in the screenshots below:
(2) Fldigi and digirig Configuration > Soundcard > Devices (now):
(2a) Fldigi and digirig Configuration > Soundcard > Devices > Playback (now):
(2b) Fldigi and digirig Configuration > Soundcard > Devices > Capture (now):
I think this could be an issue with the serial port. Could there be a conflict with some other application or process on my Pi?
Can anyone help me to figure out how to get the digirig to appear in Fldigi again?
(Troubleshooting note: I know the digirig is working correctly because it works fine with Fldigi on my Mac mini.)
======== Background =======
The digirig is still visible in terminal:
rob@pi41:~ $ lsusb
Bus 002 Device 002: ID 174c:1156 ASMedia Technology Inc. Forty
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 009: ID 0bda:8152 Realtek Semiconductor Corp. RTL8152 Fast Ethernet Adapter
Bus 001 Device 008: ID 1ea7:0064 SHARKOON Technologies GmbH 2.4GHz Wireless rechargeable vertical mouse [More&Better]
Bus 001 Device 006: ID 248a:8368 Maxxter Wireless Receiver
Bus 001 Device 010: ID 1546:01a7 U-Blox AG [u-blox 7]
Bus 001 Device 004: ID 1a40:0101 Terminus Technology Inc. Hub
Bus 001 Device 007: ID 10c4:ea60 Silicon Labs CP210x UART Bridge
Bus 001 Device 005: ID 0d8c:013c C-Media Electronics, Inc. CM108 Audio Controller
Bus 001 Device 003: ID 0424:2412 Microchip Technology, Inc. (formerly SMSC)
Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
rob@pi41:~ $ ls -l /dev/serial/by-id
total 0
lrwxrwxrwx 1 root root 13 Apr 9 08:59 usb-Silicon_Labs_CP2102N_USB_to_UART_Bridge_Controller_64bf92b62e67ec11aa902142ef680de7-if00-port0 → …/…/ttyUSB0
lrwxrwxrwx 1 root root 13 Apr 9 23:25 usb-u-blox_AG_-_www.u-blox.com_u-blox_7_-_GPS_GNSS_Receiver-if00 → …/…/ttyACM0
I believe we are discussing this exact issue over here in this thread → Help: unable to select Digirig after RPi 4 update - #11 by JBow
