FT-817 Iftx and Digirig mobile - No transmit
Hi.
I just got my Digirig Mobile and cables and tried to set it up on my Ipad with Iftx.
The Ipad got a lightning connector and I have a camera adapter for USB conversion.
Now, the receiving seems to be just fine but when I try to send the 817 never switch to transmit.
All radio settings is checked, Iftx got access to the mic.
Any ideas?
/Martin
i’m sorry i don’t have much to offer, just not familiar with iOS stuff.
the digirig mobile REQUIRES the os to use the serial port.
either by toggling the RTS line of the serial port which is connected to the audio+ptt jack of the digrig mobile
OR
CAT/CI-V/remote control command over the serial port jack of the digirig mobile
if the iOS allows either of these, it would be a matter of selecting the appropriate method within iFTX which i also no nothing about :slight_smile:
hopefully someone conversant in iOS and Lightning adapters will jump in.
Thanks. The cables are from Digirig but the Lightning to USB adapter is not a genuine Apple and I have checked the settings in my rig and receiving is ok and I can see Iftx is trying to send, so it must be something wrong between the Ipad and Digirig mobile, if nothings wrong with the settings? :slight_smile: Well,I guess I will found out sooner ot later and then I will post here.
Martin /SH6NEA
An update. I got it working with PC and WSJT-X but still no success with Ipad and Iftx.
