Has anyone used Digirig with FT-857 and RemoteHams?
I have connected everything up as suggested, adjusted settings on the radio and connected ok to RemoteHams server software.
When using the client software from another location, I can connect to the radio, control the frequency, listen to the QSO’s, press the PTT and see that the radio is transmitting. But there is no audio coming coming from the radio when I talk on the client program. The RemoteHams forum suggests that I might need to connect to the mic interface instead of the data port or adjust the digital settings on the radio for PSK instead of “other”. I tried this and it does not work.
George,
I’m not familiar with the RemoteHams software, but to determine if the issue is related to hardware, audio levels or remote software configuration I would first try to use digital modes locally (e.g. WSJT-X test). Based on the results of the test you can focus your troubleshooting efforts.
VY1GP I’m trying to do the same with an Icom 7000 and although it’s transmitting the audio sounds terrible. I’ll experiment with the settings from Setting Audio Levels For Digital Modes – digirig but I’m curious what worked for you.
KJ7MEB Elisabeth
I put the project on hold for a bit and ordered a CAT USB cable. Too many projects … Have been working on some new antennas and testing them - multi-band ECFD vertical and a 40-10 doublet fed with window line.VY1GP George
