FT891 with DR891 - WSJX - On 20 mtrs RX ok Then TX ok then locked Data to just white Noise
Set up all the com port as on line instructions - WSJT-X V2.70 b4f9a4
Rx was OK - could see traffic
Tx Nil tried various set ups (could hear replays in Ft891
WSJX big list of fault codes tried Vox - TX light on rig went to TX when I stopped TX no RX just a white noise whole of 20 mtr band same.
Settings in FT891 Changed to SSB band ok rig works as should in SSB back to DATA just locked up no receive - has WJTX locked up a setting in the fT891
All other bands Data or can hear audio - why has the DATA on 20 where I was set up done this & Shut down the FT891 rx capability on the FT891
Do I need too (do not want to) do a factory reset of the FT891
73 Kit
Sorted - changed to PSK - from Others in Data that released the lock up - then reset the baud rate to 38400 not 96000 as recommended and all now working TX RX and cat
73 KIt
Congrats
