So I had a heck of a time getting everything to work. I’m not pc savvy but still wasn’t plug and play. So I currently have two windows 11 pcs. Laptop is specifically for ft8 on my g90. I got everything to work but had to install Omni rig. My issues I am having currently on both my main pc and the laptop 10m I have the full 20watts transmit the lower I go the less power I get I’m at 6 watts on 20m and I have everything up to the max. Next issue I use the same antenna on each of these in the house. If I hook into my house main pc the monitor db is 60 + the entire time. If I go to my laptop it’s low I’ll include a few photos on 10m I have full 20watts.
in wsjt-x ‘settings’, there is a checkbox for ‘remember power settings by band’
check the ‘transmit’ box (and tune box if you like)
set the power slider in wsjt-x to give you the desired output on each band.
my icoms are within a couple watts without doing this but my g90 requires it.
The issue of TX power may related to the antenna rather than digital modes interface.
Can you get the desired power on the air with CW key down?
