Hello: I have a truSDX and Digirig with the Digirig cable. I have audio and cat control working. I can decode signals and change frequencies without issue. However, PTT won’t work. I get the following error when using PTT:
Hamlib error: read_string_generic called, rxmax=128 direct=1, expected_len=1
read_string_generic(1372): retrying read timeout 1/1 timeout=500
read_string_generic(): Timed out 1.013 seconds after 0 chars, direct=1
kenwood_transaction: read_string len=0 ‘’
kenwood_transaction: read_string retval < 0, retval = -5, retry_read=3, rp->retry=3
kenwood.c(713):kenwood_transaction returning2(-5) Communication timed out
kenwood.c(765):kenwood_safe_transaction returning2(-5) Communication timed out
***3:kenwood.c(1245):kenwood_get_if returning(-5) Communication timed out
**2:kenwood.c(1848):kenwood_get_vfo_if returning(-5) Communication timed out
*1:rig_get_vfo: elapsed=4055ms
rig_lock: client lock disengaged
*1:rig.c(3534):rig_get_vfo returning(-5) Communication timed out
while getting current VFO
I’m using the correct com port with RTS selected. Mode is USB. truSDX will go into transmit mode (R turns to T on the display) and then the error appears after a second or two.
I’m using the same settings, com ports and cables to use Winlink without any issues. I’m using Windows 11. I’ve tried changing the baud setting of the com port from 9,600 to 19,200, 38,400, and 56,700. That doesn’t help. I’m using TS-480 as the Rig.
Any ideas what might be wrong?
