I just purchased the digirig lite to interface between an I phone with the new JS8 firefly app and a QRP Labs QDX. Tried various settings starting with the JS8 firefly recommended settings from its Git Hub, but no luck. Wondering if anybody has had success with this arrangement and could share there settings.
The QDX doesn’t need the Digirig Lite at all. Its single USB-B port carries both the audio codec and the CAT/serial interface, so the radio appears to the computer as a sound card plus a COM port. The Digirig is for radios that expose separate mic, speaker, and PTT lines. So for the QDX you’d just use a USB cable to the computer and pick the QDX’s own sound device and serial port in your software, skipping the interface entirely. The JS8 PTT notes you followed sound like they were written for a different rig.
I dont have the QDX, but yeah from the looks of it you should just need a USB cable with the right connections to connect to your iphone. iOS should ideally recognize the sound card, and your good to go, the radio will need to be set to vox though (I’m assuming you will need a computer to configure that part)
JS8 Firefly is GREAT and more to come from the author…
