How to connect my Kenwood TM-71A to my computer and control all with a Mackie Mixer
Looking back what you described sounds like the best solution including several options. I can create a breakout box to take RX & TX audio from and to the Digirig and route per what you mentioned. Would it be possible to send a bock diagram of what you might use to accomplish what you described?
Bob Scott
KF8CQY
This delves deeply into what it is you are trying to do. I still don’t have a clear picture of what it is you are truly trying to accomplish.
Ultimately, this is a simple interconnect. What it does though, is create a complex user environment. I’m all about education, however, creating a diagram for this, if you don’t understand what you are doing, is fraught with pitfalls.
Since you work at a VOA site, perhaps engaging with a broadcast engineer might be more beneficial. All that I have ever worked with were always pleasant and loved to help other users.
I’d encourage you to do some research on mixers and sub routing as well, then how it is used on whatever model mixer you have.
Matt
AL0R
