I am using my digirig with a Yaesu FTM-500DR via Soundmodem for both Winlink and packet (with a terminal program). Everything is working great but I’d like to switch to have the data use the B channel on my radio.
It’s not clear if this requires a hardware/cable change or if it is just a configuration issue. I’ve tried various combinations of settings but haven’t gotten it to work.
Does this require a Winlink setting? A Soundmodem setting? A new cable?
Thanks in advance…
Garry
