IC-910H CI-V cable
I am awaiting my Digirig mobile configured for the Icom CI-V. The input to the radio’s CI-V is a 2 conductor 3.5mm plug. Can I use a 2 conductor cable from the Digirig to the radio or do I need a custom cable for the 4 conductor output from the Digirig to the 2 conductgor input of the IC-910H?
In CI-V configuration both rings in Digirig Mobile’s 4 pin serial TRRS socket are disconnected so you can safely use a two contact (TS) connector.
Many thanks, I look forward to using this device!
