IC2730 winlink not working with digirig lite
I have the:
Icom IC2730
Digirig lite
Windows 11
Latest registered winlink
Latest registered VARA FM
I cannot send or receive emails
I setup the digirig lite as in this link: https://digirig.net/digirig-lite-setup-manual/
This is in the log of VARA
2026-05-11 16:53:57 VARA FM Started
2026-05-11 16:54:05 Connecting to WC4EOC-8… 1/3
2026-05-11 16:54:07 Connected to WC4EOC-8
2026-05-11 16:54:24 QRT Received
2026-05-11 16:54:24 WC4EOC-8 disconnected TX: 0 Bytes (Max: 0 bps) RX: 26 Bytes (Max: 566 bps) Session Time: 00:17
The audio input is around 50 to 75% in the green. (Icom 2730 volume is around 50%)
I experimented with audio out from 50% up to 100% with no prevail.
I am stuck now.
Any help would be appreciated.
most likely your station is ‘ok’ and there is another issue at work.
(the vara ‘log’ shows a connection and a speed for the connection so you’re getting there even if it’s not dialed in for peak performance)
VARA software version mismatch with the server you’re connecting to.
the server you’re connecting to isn’t connecting to a CMS.
it’s very low chance but can you remove your VARA license info and try to pass traffic.
lastly, winlink express should have logged the session as well and may have more info.
Hi KB0WLF:
I removed the VARA lisence still the issue persists.
I copied some info from my winlink log.
2026/05/11 00:40:19 1.7.31.0
2026/05/11 00:40:19 1.7.31.0 Vara FM Radio-only *** Connected to Winlink RMS: WC4EOC-8 @ 2026/05/11 00:40:19 Freq: 145.050
2026/05/11 00:40:24 1.7.31.0 Vara FM Radio-only Williamson County TN EMA
2026/05/11 00:40:36 1.7.31.0 Vara FM Radio-only *** Disconnected from Winlink RMS: WC4EOC-8 @ 2026/05/11 00:40:36
2026/05/11 00:40:36 1.7.31.0 Vara FM Radio-only *** Session: 0.3 min; Avg Throughput: 0 Bytes/min; 1 Min Peak Throughput: 0 Bytes/min
2026/05/11 00:50:44 1.7.31.0 Vara FM Radio-only *** Launching VARA FM TNC: C:\VARA FM\VaraFM.exe
2026/05/11 00:50:47 1.7.31.0 Vara FM Radio-only *** Successfully connected to VARA FM TNC at 127.0.0.1 port 8300
2026/05/11 00:50:48 1.7.31.0 Vara FM Radio-only *** Ready
2026/05/11 00:50:48 1.7.31.0 Vara FM Radio-only *** Radio-only session. Only radio-only messages will be sent.
2026/05/11 00:57:35 1.7.31.0 Vara FM Radio-only *** Launching VARA FM TNC: C:\VARA FM\VaraFM.exe
2026/05/11 00:57:37 1.7.31.0 Vara FM Radio-only *** Successfully connected to VARA FM TNC at 127.0.0.1 port 8300
2026/05/11 00:57:38 1.7.31.0 Vara FM Radio-only *** Ready
2026/05/11 00:57:38 1.7.31.0 Vara FM Radio-only *** Radio-only session. Only radio-only messages will be sent.
2026/05/11 00:57:44 1.7.31.0 Vara FM Radio-only *** Calling WC4EOC-8
2026/05/11 00:57:44 1.7.31.0 Vara FM Radio-only *** CONNECT KZ4IP-T WC4EOC-8
2026/05/11 00:57:47 1.7.31.0
2026/05/11 00:57:47 1.7.31.0 Vara FM Radio-only *** Connected to Winlink RMS: WC4EOC-8 @ 2026/05/11 00:57:47 Freq: 145.050
2026/05/11 00:57:52 1.7.31.0 Vara FM Radio-only Williamson County TN EMA
2026/05/11 00:58:04 1.7.31.0 Vara FM Radio-only *** Disconnected from Winlink RMS: WC4EOC-8 @ 2026/05/11 00:58:04
2026/05/11 00:58:04 1.7.31.0 Vara FM Radio-only *** Session: 0.3 min; Avg Throughput: 0 Bytes/min; 1 Min Peak Throughput: 0 Bytes/min
2026/05/11 01:01:01 1.7.31.0 ---- Winlink Express is closing ----
2026/05/11 15:06:48 1.7.31.0
you’ve selected a radio only session.
this will only send messages marked radio only, it will not pass normal messages.
also, the gateway must accept radio only messages and be able to pass them via radio.
i would try a normal message with a normal winlink session to a normal winlink gateway and see if you can pass any traffic.
top of the drop down session list, not the middle of the drop down session list.
(i don’t know what the capabilities of the gateway you’re using so i’m just guessing)
Hi KB0WLF
You were spot on changed the setting to VARA FM Winlink and all worked immediately.
Thank you for your time helping me.
KZ4IP
sweet!
