Icom 746 Pro Setup
Has anybody had experience setting this radio up with the Digirig and the cable set ordered with it?
Please see below for cable
Wanting to replace a Signalink and want CAT control.
The Din 8 connector on DIGIRig cable fits in the auxiliary port but not the smaller port the Signal link cable came out of on the back of the radio
Any advise is appreciated.
Karl
DIN8 cable is for audio and PTT. It goes into ACC1 (#11) port on the radio and the other end plugs into Digirig’s audio socket.
The angled 3.5mm TRS connector plugs into radio’s CI-V REMOTE (#7) socket. straight 3.5mm TRRS end of that cable plugs into Digirig’s serial socket.
Ok I will try that.
Thank you much!
There is also a confirmation that IC-746PRO works via MiniDin6 connection:
MiniDin6 is available in Yaesu FT-8xx cables kit. 9600 baud version is listed separately.
Thanks to your help a couple of weeks ago
it has been working great.
About 5 of us are using it on the comms team now.
K1KSR Karl
I just acquired an IC746Pro and wanting to set it up for cat control. Would care to share your configuration and any lessons learned?
