Icom IC-7100 - No Transmit Audio
Hello!
I recently purchased a Digirig (Icom model - that supports CI-V). I have the following:
Digirig Audio - 13-pin accessory port on the back of the IC-7100
Digirig Serial - CI-V port on the back of the IC-7100
I have the USB cable connected to a Windows machine running Windows 11. The USB Serial interface was recognized without any issues. The audio input/output were also recognized without any issues.
I’ve been trying to use WSJT-X and Direwolf to test TX/RX. I can verify that Digirig is receiving audio and can PTT key the radio (via CI-V).
I have the Monitor option enabled on the IC-7100. I cannot hear audio transmitting when I key the radio/send an audio signal. I also do not see any activity on the VU meter on the front panel of the IC-7100.
Could someone provide some insight as to where to start looking to debug this issue?
Thanks in advance!
JeffH
W4JEW
Looks like I just figured out my own problem. :-/
I had the DATA MOD setting set to USB instead of ACC. Once I set it to ACC and tried to transmit, I could hear the signal via the internal speaker.
Sorry to raise the issue when the issue was my own.
Congratulations! Your report here may help others with the same radio, ICOM IC-7100.
Hello, I have a similar issue with Digirig and a Icom IC-7100. I use the Data (6-pin din) connector for audio signals. RX works very well, but there is no TX audio sent by the radio. I checked the cable with another Icom radio, and it works well on TX, so the cable, the Digirig & the sofware are OK. It looks like the IC-7100 doesn’t use the TX audio on data connector. I tried every possible setup in the “connectors” menu (Data mod, Data mod off, etc), but still no TX audio. Any idea? Thank you. VE2BAP
I use these connections (first and third ones):
I found the issue and the solution! On Data2 connector, to allow TX audio transmission, the PTT must be activated through the PTT pin on this connector. WSJT uses CI-V (CAT) PTT command, so this explains the issue I had.
In WSJT I changed CAT PTT for RTS PTT, and this works just fine now.
