What cable do I need for the IC718? I didnt see a specific cable on the website. Thanks
It’s the same as ICOM IC-706 cable.
Thanks. Are there any settings that need to me made in the IC-718 menu? Also, will I need the Icom USB driver?
Re. menus: I found CI-V configuration entries on pages 46-47 of the user manual for IC-718. You’ll need to match the baud rate between the transceiver and software settings.
Re. drivers: The only thing connected to USB in this scenario is Digirig. You might need CP210x driver if your computer doesn’t recognize its COM port.
Disregard, figured out this is the wrong cable, and more.
Thanks Denis,
Clearly a case where the best course is to buy the cables from the source as what I had is not what it was professed to be.
