Hi,
Hoping for some guidance on creating a cable for the IC-735
Have it all working on my IC-706mkiig but they don’t share the same accessory connector
Have a pic of the IC-735 acc ports - see attached
Thank you for your guidance
Hi,
We’ll be connecting to ACC1
DIN8 pin 5 (AF) → 3.5mm TRRS tip (RIG_AFOUT)
DIN8 pin 4 (MOD) → 3.5mm TRRS ring 1 (RIG_AFIN)
DIN8 pin 3 (SEND) → 3.5mm TRRS ring 2 (PTT)
DIN8 pin 2 (GND) → 3.5mm TRRS sleeve (GND)
Please post your results.
Same pinout should work for following transceivers:
Thank you for this - this worked on my IC735
I would add two notes:
The pin out shown above is from the view of the back of the radio. This makes wiring the plug pretty straight forward - with the solder cups of the male connector facing up / toward you the pin out is the same as shown
— don’t over think it like I did and reverse / flip the connector over in your head and wire it backwards … ![]()
IC-735 default setting are 1200 baud, 8 bits no parity 1 stop bit (address 04)
Thank
The DIN8 cable kit for ICOM is now available in store:
pls i need the diagram for DIN to digirig hence the digirig has two socket one is for serial and the other is for audio if ok pls send me diagram thank you,73
This is now my DIN8 from icom726 to digirig and serial port rear [remote}to radio
