Icom IC-910H and Digirig Mobile wih WSJT-X rx ok but no TX audio out?
I am trying to setup my IC-910H with the Digirig mobile for Q65, it decodes fine, keys the rig but there is no audio out. Any suggestions or has anyone had a simmilar issue?
i use a dr mobile with an ic-821h
icom 8 pin cable set for the rear acc port
no issues.
obviously my radio is an older generation so there might be a menu setting on the 910h to take input audio from the acc port.
perhaps a difference of band a/b main/sub getting audio when acc ptt is asserted ?
if you plug in a pair of earbuds/headphones into the digirig mobile audio port, do you get the TX audio expected ?
