Not yet tested on an A120. Pinouts below are from Tigertronics (front mic jack) and from Icom tech support (headset adapter).
Front mic jack (RJ-45), matches the store Icom RJ-45 cable:
pin4 (PTT) → 3.5mm TRRS ring2 (RIG_PTT)
pin6 (MIC) → 3.5mm TRRS ring1 (RIG_AFIN)
pin5 (MIC GND) → 3.5mm TRRS sleeve (GND)
pin7 (GND) → 3.5mm TRRS sleeve (GND)
pin1 (+8V), pins 2, 3, 8: not connected
External speaker jack tip → 3.5mm TRRS tip (RIG_AFOUT), sleeve → GND (not a bridged output, per Icom)
Headset adapter connector J500, per Icom’s “A120 Headset Adapter connections” diagram (7 pads, pin 1 marked with an arrow):
pin1 (8V): not connected
pin2 (GND) → 3.5mm TRRS sleeve (GND)
pin3 (EMIC) → 3.5mm TRRS ring1 (RIG_AFIN)
pin4 (GND) → 3.5mm TRRS sleeve (GND)
pin5 (EPTT) → 3.5mm TRRS ring2 (RIG_PTT)
pin6 (EXTSP) → 3.5mm TRRS tip (RIG_AFOUT)
No store cable for the headset adapter connector. Per Icom, as of their last test the front and rear mic inputs are both live at the same time (no muting), so a hand mic left in the front jack will pick up room sound during automated transmissions.
