Which cable(s) can be used with the Icom ID-31?
Kevin JJ1PJI
Looks like this one:
Hi Denis and others, could you take a look at this drawing?
Do I have the wiring correct for the audio jack?
If the audio and PTT are working well, will work on the CI-V wiring next.
Thank you Kevin JJ1PJI
Ideas from http://jo3gbd.blog.shinobi.jp/Entry/412/
http://www.rockbird-vg.net/application/windows/win_orgsoft/manual/tcid51_0930/tcid51_0930.html
Yes, this checks out according to the info I saw. I built a data cable to these specs (see original post) and will try to test it out.
Well this looks interesting…
