ID-5100, Digirig Mobile, Pi4, Allstar
I am trying to use a Digirig Mobile (rev 1.9) as the radio interface for an AllStarLink node on a Raspberry Pi, with an Icom ID-5100 on the audio/PTT jack. I have the appropriate cables for my ID-5100/Digirig config
The board enumerates correctly (0d8c:0012 C-Media and 10c4:ea60 CP210x). Audio is present. In simpleusb-tune-menu, option T toggles PTT and the round PTT pad (CM108 GPIO3) goes to about 3.3 V when keyed and low when idle.
The audio-jack PTT line never keys the radio. From the schematic and the Digirig forum, the jack PTT (ring 2 / RIG_PTT) is an open-collector driven by the CP2102 RTS pin, not by CM108 GPIO3. GPIO3 only goes to the PTT test pad. ASL3 SimpleUSB has no ptttype=RTS (or equivalent). It only toggles the CM108 GPIO, and invertptt only flips that GPIO. So stock, AllStar never drives the transistor that pulls the jack PTT to ground.
A direct connection from the PTT pad to the jack pin does not work either. When AllStar keys, that pin rises to 3.3 V instead of being pulled to ground, and the ID-5100 does not transmit. The radio expects an open-collector ground on its PTT pin.
What is the recommended way to get AllStarLink PTT working on a Digirig Mobile rev 1.9? Is there a supported software path for RTS/DTR PTT in ASL3, or a specific jumper/mod that connects CM108 GPIO3 to the existing jack PTT circuit?
Thanks in advance!
Roger
you need to build and insert this between the gpio pad you have identified and the ptt line of your radio:
(the active low schematic)
this will pull a line to ground when the gpio has voltage.
every allstar link dongle had this added to it for active low ptt radios.
(just about everything)
cleanest solution is the digirig lite as that uses gpio ptt on the audio + ptt cable instead of serial port RTS.
(same cable you aready have)
I was hoping for an easy solution i.e. ASL config, but this works.
THANK YOU SO MUCH!!
N1ROG
