KI5VSJ
October 11, 2022, 1:42am
1
Hello,
Radio ID-52
Using the Icom OPC2144 ( Slim L-Type plug adapter cable for speaker-mic & headphone)
Can I use (Yaesu FT-65R Cable for Digirig Mobile – digirig ) Yaesu FT-65R Cable for Digirig Mobile Cable along with the Icom OPC2144 adapter to my Digirig?
I am unable to find pinout information for the Icom and I am unsure if the pinout is the same between the two.
K0TX
October 11, 2022, 2:54am
2
From what I understand the OPC-2144 adapter breaks out the connectors for regular stereo headphones and mic.
Here’s the pinout for Yaesu FT-65R cable:
If 3.5mm side of OPC-2144 is for headphones, 2.5mm side is for mic and if the spacing matches (7.5mm) then it might work.
KI5VSJ
October 11, 2022, 3:19am
3
Thank you for the assistance. I will measure the connector spacing and report back. I recently ordered the Yaesu HT cable from the Digirig website.
KI5VSJ
October 11, 2022, 4:09pm
4
Spacing on the OPC-2144 adapter appears to be 10mm.
VA7AYG
October 12, 2022, 4:29pm
6
Count on me for the ID-52 cable too.
I am trying to get one of those cheap handmic and give this it a try.
VA7AYG
October 18, 2022, 5:26am
7
I tried to use separate 2.5mm and 3.5mm to connect to the jacks. Unfortunately mine were not narrow enough to reach the jack.
I also could not find a cheap hand mic to buy and salvage the cable.
A baofeng cable DOES NOT have the right pitch or at least the one I got has a slightly bigger space between plugs.
K0TX
October 18, 2022, 3:52pm
8
While building the prototype cable I salvaged the cord from this fella:
Mini Speaker Mic for ICOM Yaesu Midland Vertex Radio. Model Series: ICOM IC-F3, IC-F3G, IC-F3GS, IC-F3GSN, IC-G3GT. Just clip the speaker mic where convenient and use it to listen and transmit. Cobra: HH37ST, HH38WXST, HH45WX, HH45WX.
Build info can be found here:
VA7AYG
October 22, 2022, 3:27am
9
I was about to buy one but remembered that I tried this before, these dont go all the way in the ID-52 sp/mic jack.
K0TX
October 22, 2022, 4:52am
10
Looking at speaker/mics specifically claiming ID-52 compatibility (HM-186LS), it appears that they have a wider notch with some o-ring for waterproofing:
These are pretty spendy, so I’d still go with the cheap one and give the molding a boxcutter treatment if it doesn’t cooperate.
VA7AYG
October 26, 2022, 10:47pm
12
I managed to make the cable, it works fine with the ID-52. Tested with Soundmodem. I used 4.9K resistor.
K0TX
October 27, 2022, 3:25pm
13
Did you use cable with waterproof connector or a cheaper one?
Did you have to modify the molding?
VA7AYG
October 27, 2022, 3:52pm
14
I used two separate 2.5 and 3.5 plugs, yes I had to cut/trip both, if it helps you I can do some measurements tonight.
K0TX
October 27, 2022, 4:04pm
15
Yes, somebody else following the same process will find this useful.
KI5VSJ
November 2, 2022, 1:49am
16
Here is my homemade test cable for ID-52 HT. I did not want to destroy my ICOM OPC-2144 adaptor so I ordered pigtails and a TRRS with a breakout. Works great! Now I will solder things together and clean it up.
73,
Chris
K0TX
November 2, 2022, 2:01am
17
Thanks for sharing, Chris. Looking forward to seeing the final build.
JJ1PJI
November 6, 2022, 1:39pm
18
Testing a similar cable with Audio & CI-V.
For the ID-31Plus.
OK - PROGRAMMING SOFTWARE CS-31PLUS
OK - HAM RADIO DELUXE
KI5VSJ
November 6, 2022, 6:00pm
19
Good post!
Does the CAT control work well? What are your experiences with it?
73,
Chris
JJ1PJI
November 6, 2022, 10:52pm
20
Still testing, but it seems to work.
【CI-V】無線の遠隔操作 【ID-31/ID-51/IC-R6】 - YouTube shows it working.
DIGIRIG and Ham Radio Deluxe works.
Need to test WSJT-X, VARA-fm, and Winlink.
A modified hand speaker/mic/digirig combo with PPT & PTL(push to listen) be nice to have for testing. Allowing for directed nets and monitoring signals received. Or just A/B switcher SPEAKER MIC / DIGIRIG might work.
Off topic: Does anyone monitor their DIGIRIG audio on the PC speakers?
Kevin JJ1PJI
