Identifying version of Digirig Lite
I purchased a Digirig Lite at some point, probably between 2022 and 2024, but I’m unable to confirm. I’d like to know if there is a way to determine its version. I’ve read the version might be printed on the PCB but can’t read it through the plastic enclosure.
I’d like to know because I’m considering replacing it with another Lite (1.2) as I’ve read that the previous version (1.1) can be finicky when trying to PTT certain radios. Attempting to use the Lite with Graywolf on a Pixel 8 and on a Surface Go 2 (Linux Mint) and my ID-52a and ID-V86.
The revision is printed on the back side of the board. To view it you’ll need to open the enclosure. This can be done with a sharp blade by gradually widening the gap around the perimeter until the friction-fit pegs clear the opening.
Thank you - I guess I didn’t try hard enough to separate the housing, thinking it was glued. I appreciate the response!
