When configuring sound settings in JS8Call, only “Microphone (USB Audio Device)” is available for selection as an input device. Output device selection includes “Digirig (USB Audio Device)”.
Using JS8Call 3.01 on Windows 10 Pro with Digirig Mobile.
It may be because your PC is not seeing the Speakers (USB Audio Device) because you are not using the correct cable.
It is a 4 conductor plug. Tip, Ring 1 Ring 2 and Sleeve.
Apart from that, I am not sure what else the problem may be.
Windows 10 and 11 “should” load the drivers automatically.
Good luck!
John, VK5PO
Thanks for your reply. I’m using the DigiRig cables recommended for my ID746Pro (“ICOM DIN8 Digirig Cable Set”), and these did work when I initially tested them on a different machine.
Win 10 did not install the drivers automatically, but I downloaded and installed the CP210x driver. All appears to be correct in Device Manager.
