Issue with audio settings on Win11 Dell laptops
There is a post with a problem report and a solution in the VARA group. I’m linking it here in case somebody else runs into the same issue:
https://groups.io/g/VARA-MODEM/message/5418
The issue is described as:
I then ran Digirig troubleshooting steps. Ticking the playback option showed me where the problem was. (see the 1st screenshot.) The playback only played a split second then became silent. That means the RX signal did come into USB device but not into computer/OS somehow.
The problem was also seen here:
