I just ordered a Digirig and cables (Order D-8391) for use with a Kenwood TM-V71 - can you check if I ordered the right stuff? If, not can you fix that order? Also, can the same stuff be used with the TM-D710G?
My use is Winlink, FT8, VarAC - 9600 if possible.
Charles/N4SRN
