I purchased the Digirig including the cables from the company. I have gone through several numerous configurations and I cannot get WSJT to consistently work with the Digirig and the radio.
The best I have had is I can get the CAT to work in the test but never the PTT.
i have uninstalled everything and reinstalled everything several times and the problem gets worse.
Now even the CAT while it passes the test will not even change the frequency. UGH!!
Let’s separate concerns (PTT and CAT) and deal with each separately.
First PTT. Please share the screenshot of your device manager showing Digirig’s COM port and configuration screen of WSJT-X showing PTT configuration.
The earlier one with PTT set to RTS is correct. Test PTT and let me know if there are any issues.
Could be an RFI issue. Does this happen at minimal RF power into the dummy load?
I don’t have a dummy load to test with. I can borrow one .
Thanks for the information.
Dropping RF power to the minimum alone may work, try that first.
Followup - yes it seems to be RFI. If I go over 3W I get the aberrations to the program and the radio.
Have an RF Choke on order.
Thanks for the help
Just dropping by to say thanks for this thread and this answer. Just received a DR with the TS450 cables and this was the last of the magic needed to get it on the air on FT8.
