I have been using a Kenwood TS-450 with the a digirig for several months.
After not using for a few weeks when I start up WSJTX I get rig control error.
I have not made any config changes. No matter what changes I make I get the same error message. I am ready to throw the digirig into the garbage and start with something else. It has not been a good experience.
amlib error: rig_token_lookup called for no_xchg
rig_confparam_lookup called for no_xchg
1:rig.c(817):rig_open entered
rig_settings_get_path: path=.hamlib_settings
rig_settings_load_all: settings_file (.hamlib_settings): No such file or directory
rig_open: cwd=C:\WSJT\wsjtx
rig_open: C:\WSJT\wsjtx/hamlib_settings does not exist
rig_open: async_data_enable=0, async_data_supported=0
serial_open: COM13
serial_open(229): open failed#1
serial_open(229): open failed#2
serial_open(229): open failed#3
serial_open(229): open failed#4
serial_open: Unable to open COM13 - No such file or directory
port_open: serial_open(COM13) status=-6, err=No such file or directory
rig_open: rs->comm_state==0?=0
1:rig.c(1023):rig_open returning(-6) IO error
IO error
IO error
while opening connection to rig
Timestamp: 2023-08-20T16:44:02.461Z
