Kenwood TS-690 & N1MM+
Anyone have any expirience with the TS-690, N1MM+, and Digirig? I tried CQ WW RTTY this weekend and quickly realized I had no idea if I had things set up correctly.
I don’t believe I was getting any output. Radio was keying, but RBN wasn’t showing me spotted anytime I tried calling CQ. I think I may have settings in N1MM incorrect somewhere.
WSJT-X works fine as well as JS8. I know getting my ALC levels set corrrectly involves constant adjusting. I did do the 20 db pad mod which helped some.
If you have WSJTX running including the serial CAT control then all the hardware is working correctly.
I haven’t used it yet, but my understanding that N1MM can read transceiver’s frequency via the CAT control. If port is already configured in another software that you run, the logger will not be able to access it. You can try configuring the transceiver connection in the logger while running it exclusively to make sure it works correctly. Then look into using a virtual port splitter of some sort to give concurrent access to CAT control.
