Kenwood TS2000 problem
I have a kenwood ts2000 connected to the digrig rx is fine but it will not trx what could be the problem outside of the operator
what PTT method are you using ?
digirig mobile - comport RTS, CAT
digirig lite - gpio/raboard/cm108, vox
digirig RTS CAT
with the rts and cat, i’ll assume digirig mobile.
so with the digirig mobile, you can ptt via cat command or rts toggle.
the rts toggle is easy to check using just the AUDIO cable.
unplug the cable from the digirig mobile and short Ring2 to sleeve.
this should put the ts-2000 into tx. if so, we can move on to software troubleshooting.
now, the ts-2000 supports ptt via cat i believe but this requires the serial cable connected as well as ‘matching’ the radio serial requirements in the desired software.
