Knowing if a digirig mobile is using logic level or ci-l
Two digirig mobiles came in the same box. How can I tell if it is using “Logic Level” or “CI-L”?
CI-V unit will have dot over the letter “C” on the cardboard packaging and on the back side of the aluminum case.
Thank you. I was thinking that might be the case, but didn’t want to assume. Thank you again.
Respectfully submitted
Steve A
KG7KQT
