I have been attempting to us my KX2 / Digirig for WinLink. But the radio would not key etc. So I started using the KXUSB cable that came with the radio instead of the Digirig serial cable and it started working fine… I have tested this with two Digirigs with the same results.
Has anyone else run into this issue? Could it be a driver or perhaps a cable issue?
Any suggestions would be greatly appreciated.
Please make sure you configured the virtual TNC software (vara?) under the winlink to use PTT by RTS. It’s unlikely that the other interface you connected uses the same PTT method which suggests the PTT configuration is probably incorrect.
I have tested / reconfigured, changed settings, tried WinLink and FT8. I have had exhaustive email exchanges with the guys on the KXn group and I have made no progress. I’m loathed to ask your for a replacement cable but I’m out of ideas.
Any further testing suggestions would be greatly appreciated.
Many thanks & 73,
Neil - K6KWI
PS… I did check to make sure VARA is configured for PTT by RTS.
I see your multiple cable orders, but none for the Digirig itself. If you got it off Amazon, it’s in default configuration (logic levels), you need RS-232 configuration for CAT control of Elecraft KX. That was stated in the product page for KX cables. You can modify the configuration if you are comfortable with soldering:
That’s definitely an option if you prefer not to deal with reconfiguration. You can still use your Digirig in default configuration with other radios including HTs for Winlink/SSTV/APRS etc.
