Kx2, kxpa 100, digirig
I am new to the KX2, KXPA100 & Digirig.
Looking for configuration information on how to this all to play well together. The ACC port on the KX2 is taken up with the control cable from the amplifier. Plug the control cable from the Digirig into the back of the amplifier?
Also, fumbling around the KX2 config for displaying the ALC meter.
Thank you for your input.
Mark, AC9DE
sorry, i’m of no real help.
i’m not familiar with the sweetness that is elecraft.
(Icom kinda guy with some Xiegu on the side)
i don’t think the amplifier has a pass through port for the accessory path though.
hopefully someone will come along that has experience with your rig + amp.
The KXPA100 PC port passes through to control the KX2. Control of the KX2 is good. On the hunt for audio control from the PC. Found a way to access a Win 10 version of the sound control panel. Turned off AGC and all the specialty sound setting. And set the PC to monitor the USB sound port. This gives me the impression that the signal is being properly generated. Now I am working on ALC/Drive levels. Used the method that I had with a DRA 50 and FT-891 and that didn’t work. The hunt continues…
Mark AC9DE
Here is a document that I used to set up my KX3 for digital operations, it also works for the KX2 as well. Hope this helps!
73 de Marc/W4MGL
Elecraft Digital Mode Settings.pdf (30.1 KB)
Marc,
Thank you for the documentation. This is helpful. One of the challenges I am having is getting the ALC metering enabled.
73 de Mark, AC9DE
