Macbook Air M2
Tahoe 26.4
Various USB to Digirig Mobile Including DIGIRIG brand.
2 Digirig mobiles both work the same one is larger than the other.
WSJTX 3.0.0
I can get the CAT control to work but I have tried and tried but PTT is always coming back RED
I use WSJTX 3.0 with my Beelink mini-computer and as it is, I don’t need a Digirig Mobile. The WSJT-X when set correctly pulls the PTT on my Yaesu FT-991A. You need to set the USB port correctly and you need the Silicon Labs driver. I use COMM 11. I think WSJT-X 3.0 allows you to pick a KX3 as one of the rigs it supports. I use my Digirig Mobile with my Kenwood TM-D710Gs and I have used it with a KX3 but not with WSJT 3.0. I’ll try that and get back with you.
I had similar issues with my windows computer when I didn’t have the correct baud setting with communication between my computer to my KX3. I don’t have a Mac that I can test with at this time, sorry I can’t be of more help.
