I am thinking that there ought to be a listing here of hardware that uses each of these. I note the following pages and comments
“If you are not familiar with your radio’s serial capabilities or do not know which port standard your radio uses then first find the compatible transceiver cables and look for the configuration notes in the listing.”
I am thinking of a list that is separated into categories, some of which might be:
- radios that use the RS-232 version. For example, I have been using the RS-232 version with a variety of HTs. I wondered about my Icom T8A. It seems that “TTL” and “RS-232” apply only to the serial port, and the cable set has no programming cable, which implies either digirig is OK, because the serial port won’t be used. I am compiling a text note for myself, because there is no clear clue otherwise.
- radios that use the TTL version.
Here is partly why. I searched for a cable set for the Kenwood TS-570SG. No joy. On any variants. Ditto 570. I finally found
which lists…Kenwood TS-570, Kenwood TS-570d, Kenwood TS-570DG, Kenwood TS-570S, Kenwood TS-570SG, Kenwood TS-590S, Kenwood TS-590SG,
edit 20260302a: Corrections: 1) I have been using the TTL version with my HTs, not the RS-232 version, but see my further notes. 2) I was seeking a cable for the Kenwood TS-590SG, not a 570 variant, but the comment applies. Searching on digirig.net and finding information is not always easy.
I started making notes to myself re the digirig hardware I have and how to use it, because we need to be sure not to mix TTL and RS-232 serial ports. Note especially the comments for the ICOM IC-T8A and Yaesu FT-70D. I have not yet tested the Lite with all my radios. I also have not tried programming the 480 or 590 with digirig. My notes follow:
Radio connections for digi comms and programming
digirig - TTL or RS-232 versions, Digirig Lite, USB isolator
Baofeng HT - programming requires Digirig Mobile TTL
Kenwood TH-D72A
Kenwood TH-F6A
ICOM IC-T8A - either - no programming cable for the serial port
Yaesu FT-70D - either - no programming cable for the serial port
Kenwood TM-V71A - programming requires Digirig Mobile RS-232
- mini-DIN-6 1200 baud (DATA:audio/PTT)
- mini-DIN-6 9600 baud (DATA:audio/PTT) (menu change)
- mini-DIN-8 (PC) (20260302 cable doesn’t work with MCP-2A or chirp)
Kenwood TS-480SAT - CAT, programming requires Digirig Mobile RS-232
- mini-DIN-6 audio/PTT
- DB9 RS-232 for CAT, programming?
Kenwood TS-590SG - CAT, programming requires Digirig Mobile RS-232
- DIN-13 audio/PTT
