Hi, I’ve been trying to make my Digirig+truSDX work on VARA HF Winlink, but had been unsuccessful so far. The issue is which radio should I use for the settings. If I use Kenwood Amateur or Kenwood TS590S radio models as in the truSDX forums, the radio goes into TX mode immediately when I open a session of VARA HF. Not sure now which radio model to use.
If you only have audio cable connected then radio selection (CAT) should be set to “none”.
The important part is PTT configuration which should be set to RTS of Digirig’s serial port.
At this point, I am using digirig with my TruSDX and considering the usb cable-only option a backup for when I smash my digirig cable in the pelican case lid again (ugh!)
The usb only option unlocks some really cool features, like seeing the wattage output and SWR, but it just isnt stable enough yet I dont think. And its currently not being supported by them for that reason. The cat control driver even drops out when using a digirig too, but seemingly less often. I think I might try to figure out some settings to bypass CAT and just trigger PTT with the digirig. I can set the frequency by hand if it means greater reliability.
