How do you know what version of the Digirig Mobile you have. I am asking becuase using a digirig on a Arm M1 Mac I am not seeing what I expected. You see tty.usbmodem not tty.usbserial. I do not know if the software is the same only a layout difference. I am working to get direwolf working with an M1 Mac.
I open up the case and look on the board for the revision number. Then I check the pads and connections which determine logic levels, RS-232, CI-V.
I think it is the host computer’s driver software which determines how the USB/serial names the device. Are your drivers from Silicon Labs up to date?
My Mac came with the silicon labs drivers but it may be old. I will check that and see if anything changes.
Thank you and that solved the problem. it now say usbserial.
Tim
Thanks for reporting your progress.
