MIC BTN setting for KX3
Just received my Digirig. When I connected it to my KX3 it started transmitting. I searched the forum and found out this topic: Anybody know a cause for ERR PTT on KX3 powerup?
I pulled the mic connector just a little and transmission stopped. But I thought it’s not a good idea to always perform this precise operation when I connect my Digirig to KX3. I searched through the menu and found a setting MIC BTN which was set to PTT. I switched from DATA to USB mode and changed this setting to OFF. It didn’t allow me to change this setting while in the DATA mode.
I just thought it might help somebody facing the same problem.
To Digirig engineering: maybe it would make sense to use a TRRS connector for the mic here instead of TRS. I guess that will solve the problem and it won’t be necessary to change the menu settings.
Other than that, it works just fine.
Thanks and 73,
Pavel AC4PA
Your issue was a little different, since you were pushing the connector in all the way. With the correct menu settings, the cables work correctly, right?
Right. When I set Mic Btn to OFF I was able to push the connector all the way to the socket. Until I changed the setting I had to pull it a little bit back. In that case with the connector pushed all the way the rig started transmitting.
