Using Digirig with soundmodem and can only get it working with ASFK AX.25 1200bd. The problem is that it is slow on the BBS and also when trying to download a large email it hangs near the end. I do not know if the two issues are related, but I cannot seem to get any other speed to work. Even tried HS_Soundmodem, and none of the speeds works (also noticing there is no ASFK version). Maybe when I select another modem speed or type I need to make changes other places?
Also, is Vara FM the same type of program as Soundmodem? If so would that be easier?
